Oil Level sight plug
Dazza
Do these fit where the filler plug is then fill via breather until the oil is just visible in the sight?
Or am I being a pleb? :D
paulmgreen
eh??????
www.JPPLambretta.co.uk
Dazza
:D :D :D :D
I'll start again....
Just bought one of these:Image
Does it fit in place of the gearbox oil filler plug , then top up oil via the breather so that the oil is just showing in the sight glass.
Surely that makes sense now Paul??? :D
Have a couple of glasses of wine to help...
spot on mate............
the sight glass plug ,is the one nearest front of scoot................
if oil is visable in this .......then its fine..................... :D
Dazza
Cheers sean ;)
I use the breather hole to fill the crankcase. With the scooter level and the centre hole plug removed you fill with oil until it starts leaking from the centre hole. The plug with the window is the cente one of the 3, but with scooter level you shouldn't actually see any oil. If you can see oil when level then it's over-filled surely (no don't call me Shirley jokes please). Off the stand and tilt scooter slightly towards you then the oil should come into view. Then again I do know feck all.
noggin1969
You,ll find they get all crapped up and stained anyway so you can't see nowt
Has a mind full of useless s**t and isn't afraid to use it !
noggin1969 wrote:You,ll find they get all crapped up and stained anyway so you can't see nowt
oh great. i just bought one too.
wonder why they become so, they're fairly standard on motorbikes
i did need another level plug anyway...
Dazza
I have a solution! When it gets dirty , take it out and clean it :D
RBG
Dazza wrote:I have a solution! When it gets dirty , take it out and clean it :D
Anyway it will look trick! ;)
    Users browsing this forum: Baidu [Spider], Google [Bot] and 26 guests
