Nord-Lock washers
DaveTomo
Main scooter: SX 200
Just bought a load of nord-lock washers for my wheel rims (split rims-tubes -slime) got them from here http://www.grampianfasteners.com/ Looking on the web it says to lubricate the thread? and on another video I think they use WD40 or something similar so what are you supposed to do? using them with nylocs for the rims and hubs.Can you just put a bit of copper grease on the threads then wind them in as normal.Never used them before so hoping someone who is could recommend/advise how they use them.Cheers.
jason frost
Plain nuts are fine to use, just check the studs are long enough.
http://www.nord-lock.com/default.asp?url=357.16.37
DaveTomo
Cheers Jason,think I've got it,read that page and been out in the shed and had a play.Bought about 30 washers so had a few to play with spare (only needed 20 really - 3 wheels 2 hubs)tightened them up on a old wheel rim with a very light smear of copper grease,torqued up a treat! went to take them off and you can really feel the biting point so a little squirt of wd40 and they came off.Quite impressed really and at 26 pence each well worth it,Thank you for the link.
Diablo
YAMLAM
That link is dead,all i get is this:-Microsoft OLE DB Provider for ODBC Drivers error '80040e14'
[Microsoft][ODBC Microsoft Access Driver] Syntax error (missing operator) in query expression 'optionid=170 AND productid=507 AND Id='.
/products_buysize.asp, line 45
win or lose have a booze
