won't start from cold
doggbhoy
as above....rebuilt engine fitted new kit took me a while to get it started...once started started first kick every time took it about a 10-15 mile run....ran really well :) went to bed happy
until today now won't start from cold :roll:
checked usual things spark is good checked choke cable adjustment checked choke jet every thing seems fine(changed it anyway) compression very good and getting fuel,
stripped carb and cleaned and blew out... still same.. changed plug a few times still same (though spark always apears good)
changed cap still good spark, won't start..does fire but won't run ... soles of both feet are sore from kicking it over all morning :x
30mm phbh varitronic ignition
what am i missing :wtf:
appreciate any help thanks in advance... i'm away shopping for a new fish tank with kids maybe something will come to me when i'm away :idea: ha ha
Could be it's a bit rich on the pilot and or the choke isn't closing off fully? (Make sure you have some slack in the choke cable) Mine doesn't always want the choke from cold. The only other thing I can think of seeing as you have a good spark is that the timming has slipped (woodruff key?)
Good luck
blue
Sounds like your choke isn't working, can you see your choke plunger moving up and down when you operate the cable? Could try getting someone to put their hand over the mouth of the carb whilst you kick it, see if it tries to start then.
LI150
Main scooter: Series 2 LI150
try a bigger choke jet
doggbhoy
just to update this....
it turned out to be the stator... :o
doggbhoy wrote:just to update this....
In what way? How did the stator effect warm starting?
Sent from my HTC Sensation using Tapatalk
    Users browsing this forum: Ahrefs [Bot], Amazon [Bot] and 3 guests
