Series 1 Project 59 Frame Breather
Good job so far, keep those pics coming.
Frautzi
soullad wrote:looking good .... any chance of anymore info on the floorboard embellishers. Been looking for a decent set for a while, and have you added a rubber trim to them?
Hi Mate these are from scootrs and are stainless, TBH they are quite poor the main reason I've added the rubber seal is to hide the poor wavy edge. I will take some decent pictures tomorrow.
I'm fitting them because i like the way it finishes the leg-shield to runners,these will be painted eventually so i'm not to fussed about the current finish. I have to say if i wanted polished finishers i would give these a wide birth.
Cheers Jay
Frautzi
Supereibar wrote:Lovely..... :smug: :smug: simply my favorite, oh! and btw that is a 1958 framebreather. In 1959 all the Series 1's had airboxes like the TV series 2 :wink:
Could be Jamie, i'll check the paperwork then alter the title :oops: ;)
LCGB Letter states 1959...
bazman
Knowing the job you did on the gp it'll be a stunner mate , look forward to seeing it when done.
tecnically yes fella me lad ...but the one i had had to be dated as 59 but it was still a breather
Frautzi
Have you pair logged on the wrong forum??? :lol: :lol:
Thanks all for the comments much appreciated.
Frautzi
Ok Soullad, its about the best i can do from my camera phone.
I'm trying to show how wavy / ripley the finishers are but the camera cant pick up the ripples.
Fixings are welded and will cause low spots if you tighten them too much
The seal section i'm using is a little too thick TBH and could do with a thinner wall section, or you could cut down some horn cast rubber.
Also the rear of the covers touch the side panel even with the floor board all the way forward, so i will have to sort that by dressing the side panel and bending the covers a little
Hope that helps a bit
Jay
Dell Oughta
Coming on nicely, keep us updated
Mike
Frautzi
Same here its a 59...
Frautzi
Dell Oughta wrote:Coming on nicely, keep us updated
Mike
Thanks Mike,
Will do
    Users browsing this forum: Google [Bot], Semrush [Bot] and 6 guests
