PX RIGHT REAR INDICATOR NOT WORKING
wink
Hi all, I have just got a 1984 P125xEFL, this bike has been standing outside for over 7 years. I have got the engine going relatively easily and all lights seem fine. All indicators are working except the rear right.
I have carried out the usual tests, Panel earths & bulbs and cleaned up and WD40'd the relevant connections and switches but still not working. It's not the panel as I fitted a working one and still no joy. The indicator light in the speedo is not working (but not sure if this would effect it, poss some earth???). I have now moved to checking and replacing the plunger and spring in the frame that connects to the panel.
Can anyone recommend an easy way to remove the plunger/spring unit from the frame as it's proving somewhat stubborn.
Also any further suggestions or help above would be well received.
Thanks in advance Chris
squeakmillward
usually smash them off and use a new one ;)
Craig H
Have you checked the soldered connections on the back of the indicator switch and the wires have not broke inside the sleeving or try diff indicator switch just to eliminate the switch out the problem.
vesbrettas
the first thing i would test would be to use a test lead or multimeter to see if your getting power to the frame socket and then work from there either forwards or backwards
ducksta
you say the rear indicator is not working whats wrong with it, does it come on then go off again then on again then off again mmmmmmmmm interesting :anbrgin; :anbrgin;
wink
Hi all, thanks for the help, I've finally got it sorted, it was a poor panel earth to the frame that was causing the problem. I rubbed back all the rusty connections liberally applied the old wd40 and voila, all is working fine. Cheers again Chris
Oh and Lol ducksta
ducksta
only having a bit of fun m8 :anbrgin; i had same probs after having a full vespa powder coated what a knightmare
fraserp200e
Main scooter: 1988 MotoVespa TX200
wink wrote:Hi all, thanks for the help, I've finally got it sorted, it was a poor panel earth to the frame that was causing the problem. I rubbed back all the rusty connections liberally applied the old wd40 and voila, all is working fine. Cheers again Chris
Oh and Lol ducksta
Just had the same snag with mine - after loads of trial and error and swapping bits, it turned out I had a bad connection at the spring clips, cleaned them off and they're all sorted now
1983 Vespa PX125
1984 MotoVespa P200E
