gps speedo headset
Very smart indeed!
Muppet wrote:How deep is it in the headset?
...and what's the inside diameter of the hole?
iang
Main scooter: GP-auto / gts 250
mark wrote:just waiting for payday then im going same way, did you buy the fast boost sarter and where did you put the aerial.
do the wassel dc conversion its worth it
..The speedo comes complete with the quick start wire which means you apply a permanent live to this wire and it keeps gps signal, but to be fair you don't need it, just applying 12 volts on start up is fine because it only takes 30 secs to find it's signal the hot wire just makes it instant, but in all honesty by the time youv'e farted about with choke etc it's on and ready..
iang
soulsurfer wrote:Very smart indeed!
84mm..
yes it's seems big and when i was doing it I was thinking....s**t that's big, but to be fair now it's completed i'm really happy how it looks :D
iang
joespeed wrote:
Muppet wrote:How deep is it in the headset? Looks neat,
8-)
muppet,
i hope you have checked the clearance, it does look the biz.where do you mount the ariel and most important the cost including postage?
regards
joe
Joe.. the aerial is a small magnetic block about inch and 1/2 square and about 10mm deep..Haven't decided yet to mount it permanent or it can be left in tool box and then just pulled out and stuck on tool box..but it has to see sky..but i have tested it in my shed and it seem to pick up even inside shed !!
As regards to cost , it's not cheap at $260+$40 P&P..They are quite good and only value it at $20 for import tax reasons so you don't get stung again when it comes into the uk !!
You can go on the speedhut web site and just for fun you can mock up your own design and colours etc.
http://www.speedhut.com/custom_gauge_de ... er-827.htm
Bilko
Main scooter: LI150
Great work
Bilko's Oily Blog
warts
Main scooter: honda
Looks sooo cool. I think it was this brand that got a mention in another thread, the only pics were full on, so its great to see that they are so shallow and not a prob depth wise.
I also wondered about the function/mode switch through the face, does this look waterproof?
Angry Bloke
Quality 8-)
Looks excellent
iang
warts wrote:Looks sooo cool. I think it was this brand that got a mention in another thread, the only pics were full on, so its great to see that they are so shallow and not a prob depth wise.
I contacted speedhut before buying it to ask about it being waterproof.. They said it's suitable for motorcyle use and yes fully waterproof..
Very good work iang, looks the mutts nuts mate.
1 last question ian(for now) what is the difference between the legacy and revolution versions?
