Rear spring rating
TS1-200
Just treated the GP to a new rear shock to replace the old Taffspeed one, its a Protech fully adjustable unit, before I fitting I noticed written on the bottom of the spring were the adjustable spring stop is, 275-350 which I assume is a progressive spring rating of 275lb - 350lb I just wondered how these rates compared to other suspension units, it was always a bit firm with the old Taffy shock, it does feel ok on the road, just curious really to see what other people think, the scoot is generally ridden solo and I`m not a heavyweight.
Keep on keepin on
From memory the R1 shocks are 180/225 , the weight ratio should relate to pre 1980s and late 2000s :D
14 1/2 stone and ride mainly 1-up you only need a 180lbs spring, over 14 1/2 or ride mainly 2-up go for the 225lbs.
I noticed this anomoly on my Protech, the Rich Presley site confirms this too...
http://www.richpresley.co.uk/fully-adju ... -919-p.asp
Andy is correct too as my previous R1 shock had a 180lb spring. I have no idea what the cross reference criteria is, but Protech supply direct, http://www.protechshocks.co.uk/lambretta
Nice shock too ;-)
    Users browsing this forum: Google Adsense [Bot] and 7 guests
