new bgm products
Philipp
hello,
because of popularrequest we will be offering the bgm PRO crank with 58 mm stroke and 110 mm Yamaha con rod from early next year on.
the 60/110 and 58/110 are the versions that are available from stock.
we can also do one offs with different con rods. just send me a message, only thing is that waiting time could be considerably longer.
cheers
[email protected]
0049 (0) 2238 -307459
Angry Bloke
Philipp wrote:hello,
Good news - Thanks :)
Philipp
Newly available from next year on at your bgm dealer will be the complete range of LED rear light panels.
We started December 2009 with the 12V version for the Series 3 and late Series 2 (yom 1960 onwards). The idea was born while riding with a hangover down the motorway in territorial rain to the Euro Lambretta in Lincoln.
The big point of the LED panel is that these rarely would ever fail. They are brighter and need less current.
After the great reviews we decided to do the Series 1 and early Series 2 (up to yom 1960) version as well. And these arrived a few days before.
Additionally we are offering the panels for scooters with 6V electrics as well. These are the bgm part numbers:
7673020 LED panel LI (Series 1-2, till 1960), TV (Series 1-2, till 1960) - 12V
7700009 LED panel LI (Series 1-2, till 1960), TV (Series 1-2, till 1960) - 6V
7670923 LED panel LI series 3, LI Special, SX, TV series 3 - 12V
7700008 LED panel LI series 3, LI Special, SX, TV series 3 - 6V
Wiring is dead easy btw.: black – earth, yellow – light, red – stop light
Cheers
[email protected]
Did you ever get around to sorting one out for a GP back light..??
A few of us have bastardised to fit our GP lights just wondered if there were any plans for a mass produced GP one ?
Philipp
Lam46 wrote:Did you ever get around to sorting one out for a GP back light..??
we are always open to suggestions and we will look into this for sure.
but most GP rear lights can be easily modified so that the series 3 panel can be fitted. you 'simply' have to undo the reflector fitted to the housing.
the only really problem are the original Carello housings and some aftermarket ones, where the housing is a one piece cast item. this can be modified by grinding only. what would be a shame on an original Carello one at least.
cheers philipp
[email protected]
cezeta
CANbus
Be great if it were posiable to include LED indicators to the back light looking at that photo^
11111111 = 0xFF
cezeta
this type of thing?
MarkH
That's the Series 3 version. Fits with DL/GP rear light without the cast in reflector. Run the wires, little clear silicone to the back and Robert is your Mother's brother.
cezeta
ive a serveta with cast in reflector and a vijay with the same.............bugger :roll:
