bit of shed time
soulsurfer wrote:Nice work there Martin ;-)
There's a guy on eBay that sells ready converted side casings with Kawasaki slave cylinders, look nice too ;-)
I'll look forward to seeing what you do with a Lambretta motor Tony.
dear do though :shock:
tonydevon
Main scooter: '71 GP125
just had a look at that, cant believe what hes asking pricewise, unless Im missing something?, will keep my eyes open on ebay for a cheap engine cover and look at this myself, location of the unit is obviously paramount, but nothing that a simple jig cant sort once you got one right
need to look at the thing about the GP clutch centre, as these pistons as standard are setup to push on a hardened steel pushrod of about 8mm dia
is a lot of money, but I suppose as with anything, if you cant do it yourself, then you either pay someone else or dont have it??
rocho68
tonydevon wrote:just had a look at that, cant believe what hes asking pricewise, unless Im missing something?, will keep my eyes open on ebay for a cheap engine cover and look at this myself, location of the unit is obviously paramount, but nothing that a simple jig cant sort once you got one right
hi tony , ive already had a blank cast that can be welded in and uses an aprillia rsv clutch cylinder , finish it off over xmas then that should make the conversion alot cheaper for anybody to do !!! ;)
tonydevon
Aha good luck to you. I was going to look at the cost of doing it myself. That guys making a big profit. I reckon sell them cheaper but you will sell more.
martinr
bit futher on
martinr
all done and working :D im putting it in burton custom show this sat if anybody wants a look
