kickstart question
muffster
Xbox live gamer tag: muffinator233
Main scooter: LI 125 S3
Evening folks.
The kickstart on my S3 always hits the ground when i kick the scoot over. Is this normal?
Iv'e fitted the kickstart as per the book, Is there anything i can do to stop this happening to my shiney new kickstart so i don't damage it?
Cheers.
Muffster.
It's normal they are not meant to stay shiny.
you could of course try taking your scoot off the stand first ,sitting on it and lean it over to the left a bit before kicking it over :D
Booby
Or park it on the edge of the kerb :?:
Who holds the scooterotica Key.....Dan does! ;0)
or maybe just bump it off :lol:
Supereibar
If you are using a kickstart rubber protection it shouldnt mean any harm to the lever thou.. or am I wrong here gents?
Timbo
Re fit it but put it on a fraction above the engine casing stop, then push it down and on....if done properly should kick over better........
muffster
Cheers Timbo i will give that a try.
''you could of course try taking your scoot off the stand first ,sitting on it and lean it over to the left a bit before kicking it over''
Done that....and fell arse over tit. Won't be doing it again!
Supereibar
muffster wrote: Done that....and fell arse over tit. Won't be doing it again!
I hope that happened on soft ground :lol:
muffster
No!
I was in the garage. At least no-one was watching.
