Engine Weight
CANbus
Does anyone know the approximate weight of a 225 engine with a expansion exhaust?
thanks.
11111111 = 0xFF
Supereibar
A complete standard Lambretta GP / SX 200 lambretta engine minus exhaust or carburettor weights 30 kilograms. Taking in account that an expansion probably weights about 2kgs (+/-) and you are using an iron barrel, adding the 800 grams of a carburettor, my safe bet would be in 33 kilograms, approximately. If you are using a standard flywheel or you are using a lightened one will also vary the weight by approximately 1kg.
Best,
Jaime
CANbus
Thanks Jamie, that's great.
11111111 = 0xFF
