150 / 200 conversion Kit
mark-b
Main scooter: SIL GP190
Anyone had any dealings with these 150 / 200 conversion kits & are they a good option?
What sort of quality are they? Will they need any fettling? Will the 150 gearbox be ok?
Thanks in advance
Mark
TS1-200
They will need ports cleaning up, and the piston supplied with these kits is not very good, once the ports are sorted and a decent piston like an asso is fitted They can be ok.
Keep on keepin on
bristolmod
works out a lot better if you can get hold of just a steel lined 186 cylinder- then choose a decent piston and bore to suit.
I've done a few using Scooter Restos £30 Mahle pistons at a 3 thou clearance with absolutely no problems.
Have a play around with the ports yourself- job sorted. Good power increase for very few pennies plus the fun of doing it yourself.
Scootering since 1968.
CPH Lambretta
Main scooter: DL 150 1970
No they are not very good, the quality varies alot and you never know what you'll get.
These kits have problems with rough ports, piston to bore clearance, crap pistons and wrongly machined heads.
If you really must have one of these ally kits off ebay then pay abit more and buy one of the Buzzsolomoto kits ,they cost £175 not £125 but most of the problems are sorted for you.
BUT for that kind of money I'd send a 150 barrel and head to someone like Harry Barlow at Pro Porting and get him to do a 175 conversion with a quality piston and stage 4 tune.
Cost is the same ,performance is better and it will be alot less heartache :)
Last edited by CPH Lambretta on Fri Dec 02, 2011 10:36 pm, edited 1 time in total.
Slow is the new fast!
joey
:roll: ...save up and buy a decent bolt on kit like a mugello.... :D
mark-b
joey wrote::roll: ...save up and buy a decent bolt on kit like a mugello.... :D
Yo're having a laugh, save up?... wife, four kids, scooter habit, fishing habit and that's before you allow for food & (alcoholic) drink!! Scootering on a budget is how it's done now :D
Seriously though, thanks for the replies
Mark
CPH Lambretta
I've got a Mugello 186 kit for sale if you want Mugello performance but want to save a few quid.
lamy150
you could always have your casing converted to take a
200 barrell,mb do this service i think and it isnt that
pricey either
mark-b
Probably go down the rebore & new piston/175cc route - simple, cheap & effective.
Thanks again
soosh
What pistons are supplied with the iron 200 kits anyway?
    Users browsing this forum: Google [Bot], Semrush [Bot] and 1 guest
