Nice project! Going to be interesting to see how it goes. I have SS motor on the shelf thats going to get some kind of treatment at some point. When I was looking into this I came across this page,
http://www.vespaio.net/Vespa180SS%20-%20VSC1T.htm , good pics of a scauri worked SS topend.
Also the reedmanifold prototype that Grand Sport came out with seems interesting.
"First pictures of the new GRAND-SPORT reedvalve manifold for VESPA GS160 / SS180. CNC machined and set up to use the known Tassinari V Force 3 reed valve Minarelli (Order nr: M1002).
Currently this is only a first prototype, the space is scarce, given the angles and the mainfold for the carb is still missing until now - maybe that would be a nice job for Basti MRP.
The reed valve is screwed by means of an adapter plate to the original 3 cylinder studs, no additional drilling required. For the prototype I have to cut the lowest cooling fin on the cylinder at the inlet side for 3 - 4mm, that's it.
With a reedvalve manifold it is be possible to use an available modern and improved pistons, like the PX 200 GRAND-SPORT piston. BigBore with 66.5 mm gives 208cc and would no longer be a problem! With the conversion exhaust manifold you can run a PX sport exhaust - please note, maybe you need to rework the original exhaust bracket.
The GRAND-SPORT reedvalve manifold for VESPA GS160 / SS180 was manufactured in Germany at the company MMW, thanks to Harald for their support.
Price is not yet clear, this is only a first prototype. QUESTION: Is there general interest because, feedback is welcome, thank you."
