Anyway ill post as i go and seek advice i suspect on a regular basis...
Some of my materials, begged & borrowed and iv still managed to spend nearly £100 on whats here...
Wanted to have a go with the pinstriping tape to get the shapes i wanted and see how easy it is to curve, its 6mm and i will need to do some tight curves so i may get the 3mm to do the pistripes.
Realised that i will need to have a bit of a practice with the tape as some of the lines were well off when i stood back and looked. I found i had pull the tape back off quite a bit before realining it. Can you do this? if its a one attempt only job then im fu**ed...
