honda 205 setups
maxi
Main scooter: LIS 190
hi all what set up are people using with this kit?
anybody with a ball park setup for a 28mm delly and a jl3 barrrel is tuned by dave webster
cheers maxi
Ride it hard
Train Driver
Hi maxi is that my old 205 or did you get yourself another
maxi
Hi paul I got hold of another one,couldn't get the setup right for love nor money the one i bought of you,was a nice bit of kit as well.
Cheers maxi
Ride it hard
maxi
Come on people must be fair few of us running these kits
Ride it hard
Lambretta RS205 stage 5 with Dellorto 30mm PHBH solid mount carb & PM exhaust
needle = X7 (T1 or T2 clip)
main = 130-125
pilot = 50-60
atomiser = AV266 (If AV266 atomiser is a bit rich opt for a AV264)
slide = 40
Lambretta GP205 stage 4 with Dellorto 30mm PHBH carb & 42mm Clubman exhaust
needle = X2 (T2 clip)
main = 122
pilot = 50
atomiser = AS266
choke = 70
slide = 40
maxi
How about jetting for a 34 mm dellorto anybody?cheers for that sean for above info
Ride it hard
lammer205
Hi can anyone help me here looking for a set of rings for my honda 205 do you know where i might get myself a set ,cheers Hicksy.
maxi
Any other pistons avalible for the Honda kit apart from mb piston? Just wondering!
Ride it hard
Ian Hepworth
maxi wrote:Any other pistons avalible for the Honda kit apart from mb piston? Just wondering!
There's a suzuki one that goes in (can't remember which one) that works but it's an 18mm gudgeon pin so you are looking at conrod swaps etc.
maxi
Cheers ian,so for the mb piston would I need a rebore and need head skimmed to match?cheers maxi
Ride it hard
