super monza
steve chapman wrote:if anyone is interested i have pictures on my phone that i can send to someone , and in turn they can post them on the forum , i just dont seem to be able to send pictures , just send me pm with your phone number regards Steve
PM and phone number sent :D
Juan
I'm just looking forward to the Roberto Duran V George Foreman footage when it comes up on YouTube.
Juan wrote:I'm just looking forward to the Roberto Duran V George Foreman footage when it comes up on YouTube.
sorry ....what ????
sideout
either you're on the wrong forum mate, or I am! :)
Juan
If you don't get it then tough shite, I'm saying no more.
well ...a fight perhaps ???
lifes a drag wrote:when anything is designed its put on paper called a blueprint, all blueprinting is is something thats made to the original blueprint, no more no less exactly to the blueprint, simple int it :roll:
you been on the meths
:roll:
blueprinting has many different meanings in engineering term we used to use blue dye for marking out on half of a product then lay the oposite on top any un blued areas were removed with grinders
when i had a mini we used to blue dye the heads then drop them on the block or vice versa and again look at the unmarked areas and then look to see if we could blend the areas till there smooth with no sharp areas
can you show me the innocenti cylinder inlet manifold blue print drawing for a 30mm dellortto carb please ?
CANbus
Yes blue printing does have a few meanings, if we take it in the context of the thread, it means checking something to a reference point. Designers used to reproduce their drawing on light sensitive paper then produce copies with the aid of an ammonia die/gas, the copied drawings had a blue tinge, then more of yellow tint as time went on.
It sounds like CE checks everything to his original design, good on him. Which could open up a new can of worms however, if something happened CE (god for bid) what happens to the Super Monza?
11111111 = 0xFF
tony
Main scooter: 90ss
If ce dies we are f@@ked.. period. Life will not go on. :D
Mutley... chill mate. Have a look at the first pics from a customer supermonza.I am not sure why you are SO anti a development in Lambretta tuning?
Oz.... sorry for the 'dissing' but if you are prepared to give it you have to be prepared to take it.
I wasnt sure why exactly you are interested in lambretta stuff anyway to be honest? If you are thinking of a sm kit for your p2 then you will have to chat to charley re prim compression and flow rates as I am thinking you may need to re work a little to get the expected figures as well as a one-off pipe. Also the lambretta runs in 'reverse' to your vespa so you may have to consider load surfaces and port area tolerances to make sure you dont destroy it. But thats an area for CE. He will advise.
rocho68
CANbus wrote:Yes blue printing does have a few meanings, if we take it in the context of the thread, it means checking something to a reference point. Designers used to reproduce their drawing on light sensitive paper then produce copies with the aid of an ammonia die/gas, the copied drawings had a blue tinge, then more of yellow tint as time went on.
The term blueprinting on tuning engines refers to makin sure everything is at its optimum , including matching , bearing tolerances ,shims , compression ratios ,infact anything , its closing the tolerances that a producion engine has ,tony scott is well known in motorcycle racing ,his blueprinted engines were more powerfull than the honda racing jap engines ,but it takes a lot of time to do and is not about sticking new parts together , the way i see it is that charlie has cleaned and tweeked the barrel to how he wants it ,to blueprint it i would have thought it would have to go on the exact engine it was goin on , crank in place and all the relevant timings checked etc ,thats my take on it anyway lol !
    Users browsing this forum: Google [Bot], Semrush [Bot] and 39 guests
