super monza
steve chapman
is anyone running one yet ? if so what can i expect. thanks Steve
no one on here but by all accounts they go very well
Chris CSPE
Are the figures quoted on the cam lam web site for the factory kit at £695 or the one for £795, if there for the one at £795 does that mean there's two versions of the kit? Which version Was the one that won the endurance race, if there for the one at £795, wot does the one at £695 do. A standard TS1 would be described as straight out the box or a factory kit, would any work on it after that make it a tuned kit.
joey
...be interested too...i've heard that the 'Monza' [not super monza] kit has been further improved...can anyone confirm this...
steve chapman
hi chris i will answer what i can
mine is the super monza which has been tuned by charlie at £795
the standard one which is the one that won the 6 hr endurace is £695
not sure if that helps but its all new to me aswell Steve
joespeed
steve chapman wrote:hi chris i will answer what i can
so have you had this on a dyno?what else are you running with it ,carb,exhaust,ignition,gearbox clutch etc, have you got some dyno graphs you can show us?
drew2
so is the more 'expensive' kit better than the 'cheaper' kit,does it run
the same carb,exhaust,clutch etc as the 'cheaper' one,does it use the
same fuel?,questions questions
Chris CSPE
Thanks Steve, a clear answer to a question, it's a bit frustrating to get info on wots wot, hows it been Steve, has it ran and performed as you expected or has it surpassed your expectations.
steve chapman
hi guys only got it yesterday and its still sat on my lounge table , now need to save up for the other bits , no cutting corners so its going to cost a few quid
wezly
As i understand it the more expensive kit has been blue printed by charley, not tuned as such. Charley 6hr road bike would have been blue printed for sure.
    Users browsing this forum: No registered users and 34 guests
