master cylinder
joeswoonara
Main scooter: jet ts1
i`m using a scootRS master cylinder on a frank sanderson single disc and it lacks any "feel"when braking, it`s on or its not , have a feeling it`s too big for the slave cylinder..................anyone using a smaller master ,and what did it come of scooter, bike etc
AJP on from speedflight or dragster you will need to reshape you handle bare mount though
Thats the one I use on all my bikes as well
joeswoonara
got my new master cylinder from a speedfighter , you say i have to re-shape mounting ......in what way ? hope question like that dosent make me seem to dim :o
the half moon cut out were it locates needs to match you may have to take some of both parts
dont go mad thouth
were the mirror would go can be drilled through and into the switch mount i did mune 5mm then tapped it out to 6mm for a more secure fixing
the scoot rs mount has a bolt up through the bottom so you need to alter the ajp one same as the nissin one ...the speed fight unit is a neat looking alternative
