piston for 190 kit?
handofdave
Main scooter: li ts1
hi,
need to source a quality piston either 64.5mm or 65mm,was hoping to do suzuki 190 but just cant seem to find a high quality make ,any ideas who may have them?
cheers
Mitaka ones are good
handofdave
jonny snatchsniffer wrote:http://www.mitaka.co.uk/pistons.htm
thats great,do you know which one will work?
ForemanBob
Main scooter: GP RT230
http://www.lambrettaspares.com/spares/s ... psuzm.html
Out of stock at the mo, but that's where I get mine....
handofdave
what make are those?
ForemanBob
Mitaka
Knowledge
If you can't find Mitaka, then buy Hi-Level copy of the Suzuki TS185 piston. Any motorcycle shop should be able to supply Hi-level piston kits (piston, rings, gudgeon pin and circlips). About £40, I guess.
Martin
jonny snatchsniffer
wiseco do one too
mawso
I've both 65mm Mitaka and 65.5mm Wiseco. Wiseco lost it's ring peg after 500 miles tho, which to be fair is not a common problem with them...so prob' just an issue with mine which had very hi comp. Mitaka are good value for money pistons. HTC also do pattern pistons and can be found for approx £30.00 on Ebay (is that the Hi-Level?). I'd only go Wiseco after bore reaches 65mm and you can't get Mitaka ones then. Wiseco are forged too and cost £70.00 +
