YZ250 conversion
Chris CSPE
With the room that it has above the barrel will it be fitted with a down draft carb straight above the inlet or a long manifold and a carb. The down draft would be better for performance and less work.
tony
Main scooter: 90ss
drew2 wrote:cheers mark,will do.
this is the new engine bracket rocho has machined to mount the engine,the mark
is where the bracket will be cut out for the carb
That is neat.
Chris CSPE wrote:With the room that it has above the barrel will it be fitted with a down draft carb straight above the inlet or a long manifold and a carb. The down draft would be better for performance and less work.
perhaps one like the dac bike used ??
drew2
the engine bracket on the engine showing the cut out for the carb,
tonydevon
Main scooter: '71 GP125
so long as your happy, but slugs in my opinion and experience should be hollow, similar wall thickness to the tube your joining, and ideally about 1.5 times the diameter in length
some nice work going on there, I look forward to seeing more of it
rocho68
tonydevon wrote:so long as your happy, but slugs in my opinion and experience should be hollow, similar wall thickness to the tube your joining, and ideally about 1.5 times the diameter in length
Hi tony ,yes its hollow and the same thickness as the tube
Cheers lee
willwander
drew2 wrote:
How does it attach to the rear part of the frame?
standing mile: 118.6mph
willwander wrote:
think it was mentioned in an earlier thread that the was to be some mono shock arrangement like the cutdown bullet /rough diamond etc
drew2
frame is now ready to be cut
chop chop .. :lol:
    Users browsing this forum: No registered users and 55 guests
