removing electric start gear on PX flywheel
vegansydney
Just picked an an electric start PX flywheel as they are marginally lighter than the earlier non-electric start ones. What's the best way to remove the electric start gear ring/cog without damaging the soft flywheel alloy?
Thanks!
hungdog
Just tap it off with a hammer and large flat blade screwdriver, working you way around it don't try and lever it off against the flywheel as you will damage the flywheel. :oops:
cezeta
or cut straight through it with a hack saw and it will fall off
goldeneye
just cut thru it with a hacksaw, and ping it off. easypeasy. mind, some early p-range casings wont let a disc flywheel sit fully "home" on the crank, they have a web of ally at the front of the casing , that the flywheel doesnt clear. either machine the flywheel (beedspeed does this for a tenner or so) or grind the casing. i"d machine the flywheel myself. contrary to popular belief, not all P-range engine bits are interchangeable. some need fettling.
gaz_powell
goldeneye is correct - i`ve just put a electric start flywheel on my early (pre autolube) and had to machine a a lip in to fit the casing - took me 20minutes on a lathe (longer to set it up than do it) - you will see what is needed when you compare it to a
good thing was the electric start flywheel with the ring off was lighter than my original which had been lightened
i just knocked the ring off as hungdog said
vegansydney
Thanks for the heads up! :D
The cases are early Rally 200 and a lip has already been machine in the casing. Would have kept it FEMSA but a local 'mechanic' butchered the stator beyond repair so 12v PX Ducati conversion was done--now just want to lighten the flywheel from the standard early P-series.
    Users browsing this forum: Baidu [Spider] and 2 guests
