external front suspension
tonydevon
Main scooter: '71 GP125
Greetings, I was wondering where people get the suspension setups that they use on the lambretta forks, the complete shock on the outside, not just the damper
anyone tried the suspension from monkey bikes etc??
I have a set of bare forks and so thought it easier to just go with that setup rather than buy all the bits to go inside the legs etc
will probably make my own links as Im going to be running 15mm axle, unless I find alternative bearings, but at least if I make my own links, I can make sure the bolt for the shock is welded properly, and the axle hole will be full circle.
Stampede
Main scooter: SX200
The monkey bike dampers on a lambretta fork are much too stiff for a good suspension.
tonydevon
ok cool thanks, any info is good info, so who supplies the kits I keep seeing fitted to peoples scooters?
are they hard on the front end?
I like to have suspension that works.
CPH Lambretta
Main scooter: DL 150 1970
Try Lambretta Innovations /Frank Sandersen
Slow is the new fast!
Stampede
Main scooter: SX200
CPH Lambretta wrote:Try Lambretta Innovations /Frank Sandersen
Yeah, they don´t use monkey bike ones. They look similar, but are much smoother in damping!
Here you go Tony, these are the ones Frank does. Not sure what they are off originally. Just give him a bell mate.
tonydevon
aha now they are what Im talking about, seen some chrome ones, but dont like them, they look a little cheap
those looks great
in your opinion, do they actually work?
thanks
just found them on the PM-tuning site, Bitubo basically £200 a pair, bit rich but if they work then I will have to add them to my xmas list LOL
mickdale
do they fit with a standard gp mudguard ok?
cheers
mick
yes
Tony I can't comment yet on how they handle but Frank has sold hundreds of sets so far. Mick, as Ric says they do fit with a standard mudguard.
    Users browsing this forum: Google [Bot] and 89 guests
