small block gse 200
col68
Main scooter: lambretta s2 li225 ts1
Has any one fitted a gse 200. How has it been running any problems that i will need to know about before it is fitted . It is stage 4 tuned at moment has any one tuned one ? Going in an li150 italian, li 125 gearbox, 30mm phbh carb fresco exhaust and changed piston to a 2 ring mahle . ta col
nuttyboy
hi i had the gse kit lasted 400 miles ..mainly due to crap engine builder.kit was ported to stage 5.was told exhaust port should of been left alone . was alot of money for what it is .have since had 185 kit fitted with same performance. suggest you fit it without porting .hohe it helps.
lamblast
it you do a search on here for "gse " i wrote how to do one on the cheap weve done 2 both running fine .the one was done for under £30 using a second hand top end .the other was under £100 so cheap as chips they are just the same as a normal large block 200 running wise hope this helps
col68
thanks for that will have a look .ta col
soosh
Std.spec of this barrel is ok. Good with 28/30 carb and bigbore.Reliable too.My kit is based on this barrel and no problem at all.Getting on for 10yrs old.
    Users browsing this forum: Google [Bot], Google Adsense [Bot] and 2 guests
