175 conversion
- Xbox live gamer tag: Pleasure Master
- Main scooter: lambretta gp150
150 to 175 iron barrel, which make piston of should I go for?
- Main scooter: DL 150 1970
Asso/Vertex
Slow is the new fast!
Asso / Vertex with 2 thin rings... a good clean rebore and then Honed to size..
cool, apart from a bore and hone what else do i need to do? re-profile head,increase port sizes,check port times,check squish anything else or all of the above?
cheers
frank
cheers
frank
you could fit a std 175 head or skim and profile 150 head to suit.... as for porting I would at least widen the exhaust port....but no more than 62% as the rings are cast....
Can anyone share part numbers for the above mentioned pistons?
Anyone?
make sure you get a conversion piston not a std TV oneJ1MS wrote:Asso / Vertex with 2 thin rings... a good clean rebore and then Honed to size..
part number wise id just go for a piston from a main dealer they will know what it is
http://www.afrayspeed.co.uk/online_cata ... stons.html
