Malossi 210 barrel
MCH
Main scooter: street racer px
is this barrel still usable?
it has a small score mark between two of the transfers, what do you reckon?
smiffy1968
Main scooter: Nevermind Mk1 T5
I've done thousands of miles on a lot worse barrel than that. Although it was not a full on tuned engine.
joeythescooterboy
I've used worse, a lot worse, just smooth the score over with a bit of wet n dry. It's below the transfers so you shouldn't lose too much compression.
First thing I'd do though is look for what caused it???
MCH
It was stripped off another engine, piston had tried to hole, but the top and one side had broke off which caused the score I guess, should I use the piston rings from the piston for my new piston or just get new ones?
joeythescooterboy
I'd get new rings fella, it doesn't take much to knock them out of shape and you'll run the risk of getting lots of blow by.
225worb
Main scooter: Vespa 225, Falc , 230 S2
dude thats got loads of use left it, they are pretty robust though the pistons i find crack under the ring piece lands, just polish out the rough edges of the score then stick her back together :fb:
MCH
cheers fellas
im just collecting all the bits i need to build my malossi 221 monster of a machine, slow progress, but im getting there, just need advice on gearing now as im running an over sized tyre on the back and so need to up gear it,
going to keep the cosa clutch though, buying a milled out basket for it as i know cosas are crap for handling the power im looking for
