Dev Tour - what gearing?
mawso
Had planned to use a Saigon Taffy to pull LI125S 19/46. But got hold of a Dev Tour instead. I know they're more aimed at mid range but had hoped they can pull 4.8 with luggage. It's a piston port long stroke engine.
I found 5.0 works well, 4.8 was a bit tall on mine riding solo.
Bilko
Main scooter: LI150
Just what I wanted to hear.
My gearing at 5.0 as I await delivery of my Dev - Tour.
Bilko's Oily Blog
soosh
Do they still do a Rev tour? Though that was the pipe which worked best on non reed motors?
mawso wrote:It's a piston port long stroke engine.
Ah, didn't see that when I was on the iPhone, scrub my comment as that was TS1 :oops:
Bilko wrote:Just what I wanted to hear.
Are they back on Sale ??
Bilko
Main scooter: LI150
No Toddy, sorry mate, I've a second hand one coming my way.
Bilko's Oily Blog
Mag
Main scooter: Carbon GP TS1
soosh wrote:Do they still do a Rev tour? Though that was the pipe which worked best on non reed motors?
My Rev Tour is alright on my TS
paul213
my reworked v1 muggy 225 std stroke pulls 4.8 with a devtour and acording to rev counter tops out about 8000 in 4th
pulls ok 1 up with luggage long hills require changing down
tried this after mk4 taffy that realy pulled, accelerated up hill in 4th but limited top end to 7000 rpm I wanted just a bit more top end for motorway use , trouble is now at 7000 rpm it stops vibrating and becomes silky smooth all very scary
hope this helps
mawso
^^ Yes I like the sound of that...your engine must reach nirvana, enlightenment and inner peace at 7K then haha!
I asked Mark on his FB page what gearing he recommended and he suggested something a little lower and to let the engine work a bit more. I have a rev counter fitted and will be interested to see what it will rev onto. I liked his description of it being tractable, torquey and geared correctly having auto characteristics in 4th; where you can wind on from quite low speeds and build and build.
