ts1 250 iron lined cylinders
roadrunnerian
has anyone had some experience with the set up. what are the pro's and con's thanks
Chris CSPE
I had one done years ago, it was a TS 225,cast linner,and a Wiseco piston.it did just over 30hp. I kept it for a couple of years before selling it to my brother, he's just bought it in for a re-build after 11,000 miles. It's had a new piston and a re-bore,which is alot cheaper then a ceramic/niccasil re-line. A cast linner is great if done well , you get the best of both worlds, if it's done badly then your barrel can end up as scrap.
