PHBH slide upgrade?
mickdale
http://www.thunderproducts.com/u_f_o.htm
anyone got an opinion as to its merits if it will fit the PHBH slide?
cheers
mick
nelson pk
The potential benefit is that on a round slide carb the air "eddies" at small throttle openings causing turbulence and the mixture doesn't atomize as well as a flat slide. In fact thats why flatslides were created.
In other words throttle response is not as good as say with a flat slide carb which has a much better airflow through the slide.
However i think you would need a dyno session with an experienced operator to set it up correctly.
soosh
nelson pk wrote: However i think you would need an experienced operator to set it up correctly.
mickdale
thanks nelson pk - gonna give em a ring and see if they will fit a PHBH, if not might have to make one as they seem simple and a good idea
nelson pk
No Probs.
Thats not quite the operator i was getting at :lol:
