30phbh leaking
shureimage
Main scooter: SIL GP200
I've got a problem with my carb it's leaking fuel between the body & the bowl, I've replaced the rubber o ring gasket, but its still weeping, it seems mainly concentrated around the corner beneath the mixture screw.
Any ideas ?
Cheers Dom.
shureimage
The float bowl is held on with a single bolt underneath, oh & it's a plastic bowl.......
shureimage wrote:The float bowl is held on with a single bolt underneath, oh & it's a plastic bowl.......
Wondered if it was, same as mine..have you replaced the small gasket on the main jet housing bolt which holds the bowl on and make sure when you have seated the o ring correctly with no bits in the groove. not much else that can go wrong really..
    Users browsing this forum: Google [Bot] and 13 guests
