P200 Starting Problem
Lamaddict
It's a 1980 standard P200 with nearly 11,000 orginal miles on. It's hard to start when cold. The choke is fine and I've cleaned out the carb. I thought I cured the probelm by changing the original supressor cap but it's too hard to start again after being left for 2 weeks. I'm wondering about the piston rings and if they need replacing????
I would certainley check the rings/piston and bore at your 11k,in fact it should have been checked ages ago :lol:
Lamaddict
sean brady scooters wrote:I would certainley check the rings/piston and bore at your 11k,in fact it should have been checked ages ago :lol:
OK thanks, where's the best place to buy some standard, genuine new rings from?
