Dye to show hairline cracks
its an animal based lubricant
bit like lard
when animal wast lips nips dicks and all the other none edible bits are rendered down in a seperheated steam vat with a big paddle running through it fats are drained of at certain temps and used for different things
, the dried wast can be bonemeal and is used as i a firtilizer
there is one redering mix which uses blood and feathers and is gross , the blood offle one are done in chard in summerset for brook bond -oxo and make yes oxo cubes
repairing these machines was the most didcusting job ive ever done and the smell is outragious second only to down town BASRA in IRAQ
Stampede
Main scooter: SX200
mark wrote:What's tallow?
Sorry, meant that you have to apply the toothpaste on the same area where the WD40 was.... :oops:
mickdale
i will post the stuff for free if you pay postage - will be 3 aerosol cans about same size as small rattle can
will explain how to do it correctly over phone if you decide to go down this route
mick
DMC
Dont do it mate, you'll be in for a shock!
john.t5
DMC wrote:Dont do it mate, you'll be in for a shock!
Surely ideally you'd do it on the inside though??
john.t5
Well, thanks to Mickdale I have checked the casings and all seems well, although I now think the problem may be at the retaining plate.
Thanks again Mick, I really appreciate your help :bigsm:
mickdale
no worries john
its what the scooterotica forum is all about :-)
