lambretta losiing power under load
col@garageartwerks
got a strange fault on a friends bike....
he has an li 150 with a 175 kit on it, a 22mil jetex and 42 clubman.
he has just done a 700 mile trip around france with his wife averaging 60 mph
since he's come back he's noticed a lack in power on the bike, having to change down gear to climb hills.
the bike will rev out while on the stand but when ridden it won't rev out in 3rd or 4th its very hesitant
heres what i've changed...
noticed there was no gearbox oil in, crankcase breather was blocked so have unblocked that and have fitted new crank seals,
have tried 3 cdi's
have tried 2 stators
new plug
new cap
new ht lead
the full electronic system off my gp
cleaned carb jets
checked air filter for blockages
stripped and checked top end
replaced all top end gaskets
still ran the same after all this was changed....
only thing i haven't tried that i think it might be is
change exhaust or check for blockages
any ideas ????
its a strange one that has baffled me
It could be the exhaust, possibly the baffle has worked loose?
What is the compression like? I could be a stuck ring?
soullad
worn carb slide?
did you check the ring gap when you stripped the top end?
ove
Did he eat too much and now weighs 2st heavier? :oops:
Linford_Li
Its my scoot,
And the answer is NO!
Linford_Li wrote:Its my scoot,
:D ..Busted..
bsso78
Sounds like it needs a rebore or new rings to me
Timbo
Have you checked the u bend for a split........had this recently.........
