Clubmans ?
carlos fandango
Thinking of fitting a clubman on my S1.
Are there any fitting issue or should they go straight on (if there is such a thing with lammy bits :lol: )?
Is there much difference between makes? Which is best / worst?
Cheers
Russell
some u bends are at the wrong angle the proper AF ones are normally ok but not always, blow torch and ratchet strap time :shock: ,if you buy one from a local dealer you can fire it back to his asap if it dont fit
lammydave
AF
mine fitted perfectly and looks and sounds excellent!
bristolmod
lammydave wrote:AF
ditto- although I also bought a cheap Indian one and that also fitted perfectly (didn't sound as good though)
Chris
Scootering since 1968.
