t5 horn
marktheskin
Main scooter: SIL GP150/vespa when its broke
hi im fitting a standard horn back on my t5 1996 after it has had air horns fitted at somepont and cant get the spare wheel under the side panel som im getting rid.
are the black and white, and the black wires(ihave found loose under my horncast) the ones for the horn? these two wires seem to come from the headset put cant pull the switch panel out far enough to see the wires.
if they are does the horn need to have an earth or is it just these two wires?
any help would be great,
cheers
ducksta
just plug the wires in anyway around m8 and horn will work
gaz_powell
would agree with the above - just try it but horn wires are usually yellow and blue
