Fuel Gauge
PRE0ATS
Main scooter: Li Silver Special
Apologies for resurrecting an old thread, but have either of you guys that ordered the dip-type sender from asap get it up and running?
I'm thinking of adding a dip-type sender and gauge to my current project, but am a little unsure about what will need doing to the fuel tank to fit the sender to it (will be a new 12/13 litre tank), so have a few questions:
Will the tank need a plate/ring welding into the top?
What do the 5 sender screws/bolts secure into?
Is the supplied washer sufficient to seal the sender and tank?
Any advice would be much appreciated.
A
jonashford
Hi, it's a yes to all of those questions, lol
Spud
jon, which faris gauge did you use, does it have a backlight?
Also did it come with wiring instructions?
cheers
Spud
jonashford
Hi Spud,
I use this one,
http://www.asap-supplies.com/marine/fue ... 9373-13801
It has a backlight and comes with instructions, just wire the light off your black wire in the headset
A little tip to avoid having to weld your tank is to use Rivnuts http://www.youtube.com/watch?v=htW_dQ_f ... re=related Your local engineering place should be able to do them.
jonashford
Gud idea that
gonzo-jetsonslc
Main scooter: Lambretta SX 150
I bought a complete set of a sailing shop that looked a bit like this: http://www.ebay.co.uk/itm/12V-FUEL-GAUG ... 916wt_1114
No welding required, it just screws on the tank. It is a bit "fiddly" to get the in-tank plate through the hole but after one hour of hard work it was done and has no leaks for 4 years now. The man behind the counter pointed out that one needs to check out if the sender unit actually works with the gauge, because of varying resistance. So it might be a good idea to buy a set.
The sender unit in the tank is very easy to cut to the right length, so I can recommend them.
It even works with no battery if you have some kind of DC converter like the Koso one.
cheers gonzo
if you use wellnuts as mentioned in our conservation on phone you will be fine
