Winter Model, Summer Restoration...
Things have slowed down a bit at the bodyshop for the moment :-?
Anyway, I've managed to get the headset the way I wanted by obtaining and restoring a genuine light rim that was badly corroded and several holes drilled in it. My plater silver soldered them up and then heavily copper plated it prior to chroming. He had some problems with the new chrome bubbling up, but persevered and did a pretty good job IMO. These look chunkier than other S3 rims and fit nice too...
The other thing I needed to sort was the reflector. I got a couple of quotes in excess if £100 for re-silvering :shock:
Again my man came to the rescue and chrome plated it for the princely sum of £20
cracking job on the rim ...i bet thats a weight of yer mind
Tommy Boy
Main scooter: Series 1 with a Twist!
soulsurfer wrote:The other thing I needed to sort was the reflector. I got a couple of quotes in excess if £100 for re-silvering :shock:
Who's your man? I need this doing to both my series 1 reflectors and it looks like a top job.
M.D.M.A. Scooter Collective
He's near Croydon Tommy. If you can get them to me, I'll drop them in for you ;-)
RICSPEED wrote:cracking job on the rim ...i bet thats a weight of yer mind
Oh yes :D
I thought there was a reason that reflectors were silvered as opposed to chromed?
Doom Patrol wrote:I thought there was a reason that reflectors were silvered as opposed to chromed?
possibly but i cant think of a good reason why chrome is not as good other than there may be a slight diffraction of light and on a lammy i guess you will not notice anyway
Ive been racking my brains since Mike posted the picture as I am also sure this is a no no..but can I feckers remember why..the only conclusion I can come to is because its so shiny bright and the standard backing would be slightly duller ???
I could be talking out me arse of course...no change there then Red would say :D
if you compare the two pics again ...the silvered one (where good) the reflected image is sharper where as the chromed one is slightly blurred ..although this could be down the mike not being so steady with the pic taking
I would imagine that silvering would be the purest reflection as I believe it's the same process used to make mirrors, hence the massive price to refurb them. My plater did say that he usually nickel plates them, I didn't ask why he chromed mine. I'm sure there are reasons/pros and cons, but I doubt there will be any visible difference when used with its 47 year old lense :-)
It must be something to do with the way in which it reflects light. But as you say it's hard to see what difference it would make in real terms. I think the actual ribbing in the glass is probably just as important. I have a genuine Italian GP glass and recently fitted a cheapo Indian pattern one out of necessity and the spread of the light is very different.
