t5 /ts1
ducksta
can you fit a ts1 to a vespa t5 engine and if yes who can do it
C*NTSPEED
u can put a top end on oz is yer man plus yer bank manager
GEMINI S.C.
BLACK WIDDA'S S.C.
ducksta
any idea on price and overall result speed reliability etc
OzOAP
Main scooter: Vespa PTS1E
T5 casing, AF TS1 barrel, extra boost port, 188/128 port timing, Readspeed centre plug head, Wossner Yamaha YZ 250 piston,
V-Force reed block.
Mikuni fuel pump.
Crank: Full circle P200, (57 stroke), widened 10mm. Rotax 120mm rod.
Pipe: PM.
Timing: Parmakit set to 12 deg @ 9000 revs.
Clutch: Old style 7 spring 21 tooth.
26hp/20lb torque
Has done prob 8000 miles and hours on dyno.
2 Pistons, 1 due to carb set-up (pre dyno), other due to drive side oil seal.
As reliable as most tuned bikes.
80 miles on 12lt tank.
Wont be building any more, got my own projects to finish.
Goes fast enough for me.
ducksta
cheers
    Users browsing this forum: No registered users and 26 guests
