Quattrini M1XL Intake question.
tynesidevespa
Main scooter: 2002 Vespa Px 125
Just before i order this kit a quick question on the stock intake that needs to be deleted/filled.
I guess there is 2 ways to do this either get it welded up or get a plate made to bolt down,any thoughts on either method or maybe you've done it.?
Cheers lads.
goldeneye
are these the reed on the barrel quattrini? they come with a plate to block the crankcase intake.
OzOAP
Main scooter: Vespa PTS1E
I put a plate over mine when I TS1'd my P Range.
Welding/filling would make little difference to crank compression.
tynesidevespa
goldeneye wrote:are these the reed on the barrel quattrini? they come with a plate to block the crankcase intake.
Thats the one,no mention of the plate being included on sip's page though,easy enough to knock one up i suppose,cheers for getting back.
gadgetman
I've got this kit and I've run it for the last year . Anything you want to know just ask.
C*NTSPEED
gadgetman wrote:I've got this kit and I've run it for the last year . Anything you want to know just ask.
U do all the work yer sen pal
Could do with a few pointers before i take the plunge
GEMINI S.C.
BLACK WIDDA'S S.C.
gadgetman
Yes , everything other than final dyno set up and fuel pump which was done by Martin at Chiselspeed. The main bits were researching which carb would fit and finding and modifying a suitable air filter plus a bit of welding to strengthen the casing. and increase crankcase compression It's a full rebuild including crank, clutch etc. When i first built this engine to my knowledge it was one of if not the first in the UK so a lot of time was spent on research. It's a PX125E block fitted into a 1963 GL frame. Very rideable with plenty of torque and will wheely in 2nd if you're not gentle on the throttle but like any kit there is more performance available if you want to tune it further. Mine is a fast road use rally going bike and has done a few long distance rallies including Killarney , Ireland - 500mile. Isle Of Wight 400 mile and last week the LCGB Coast 2 Coast 350 miles. The latter rally highlighted a cooling issue with the lightened flywheel but that is now sorted. If I can help in anyway I don't mind passing on my experiences with this kit.
ducksta
hi gadget any photos and can you put a full spec up please
soulboy
are these for the large frame vespas .and will they fit the 125 ? also how much are they cheers ;)
ducksta
vespa px 125cc scoots m8
    Users browsing this forum: Baidu [Spider] and 1 guest
