s2 v s3 rear boards
a7grenade
Main scooter: 1963 Li150
can anyone help pls? what are the issues using s2 foot boards and s3 legshields
is there a width difference?
maybe this can be sorted with cutting and re-welding? / shaping
(im using s2 side panels and loop but s3 front end)
if anyone has any dimensions i would appreciate-thanks
j
the series 1/2 rear boards have a greater curve to the edge comared to series 3 ones true you could match up by welding a 4mm rod to the edge but a good set of 1/2 rear boards are arround 80 - 100 on ebay ,far better to extend a set of series 3 ones ...20 - 40 on ebay
a7grenade
RICSPEED wrote:the series 1/2 rear boards have a greater curve to the edge comared to series 3 ones true you could match up by welding a 4mm rod to the edge but a good set of 1/2 rear boards are arround 80 - 100 on ebay ,far better to extend a set of series 3 ones ...20 - 40 on ebay
using the panels ive bought-matching the legshields probably wont be a problem-theyre fairly rounded-hehe
cheers though-i understand now
and the prices are high-ive been finding out!
