Lambretta Gearbox Visualiser UPDATED: NEW VERSION
DMC
That’s brilliant work mate, excellent work. This has got to be the best gear box spreadsheet to date.
Now we all need to get into the work shop and build a database of all the different tyre circumferences.
Ian Hepworth
DMC wrote:That’s brilliant work mate, excellent work. This has got to be the best gear box spreadsheet to date.
Here's all the 10" Schwalbe stuff
Weatherman
http://www.mbdevelopments.co.uk/schwalb ... h_tyre.php
Raceman
Paceman
Powertrack
Classic
Avantone
Weatherman
Raceman
Paceman
Powertrack
Classic
I can build all of those options into the spreadsheet fairly easily - I'll get an updated version out soon.........
Tony
www.lambrettagearbox.com
Avantone
I've made some improvements to the Visualiser:
:D I've dropped the Macros in favour drop-downs (Tidier interface, less threat of virus and quicker to update/maintain)
:D I've added tyre circumference for the whole Schwalbe range of tyres (I've contacted Michelin, Bridgestone and Dunlop for any technical data they can give on their tyres.
:D Added the details for the DGT Pacemaker box currently being tested
:oops: Still got some issues running it in OfficeX on MacOSX
:D But works great on XP and Openoffice on OSX
If you like it you can also subscribe, and I'll send you new versions.
Thanks for the feedback so far - I'll try to build as much into future versions
Tony
Ian Hepworth
I've got all the J, Lui and lambro gearboxes in a few excels somewhere, will send them to you in the next few days.
rog60
Main scooter: Indian GP200
As you said, now works in OpenOffice. Brilliant. Thanks
RinB
Well Tony it just gets better
Spot on
Smiffy
Snails
Ian Hepworth wrote:I've got all the J, Lui and lambro gearboxes in a few excels somewhere, will send them to you in the next few days.
Found this on the LCGB forum:
J/Luna Technical Details
Vega
Cluster 9, 13, 16, 20
Loose gears
1st = 49 teeth
2nd = 36 teeth
3rd = 42 teeth
4th = 39 teeth
Primary Ratio 46/13
Stroke = 44mm
ConRod length =
Bore = 46.4mm
J125 four speed
Cluster 11, 14, 16, 19
Loose gears
1st = 48 teeth - 98.70mm dia
2nd = 44 teeth - 91.50mm dia
3rd = 37 teeth - 83.85mm dia
4th = 34 teeth - 79mm dia
Primary Ratio 45/14
Stroke = 48mm
ConRod length =
Bore = 57mm
J125 3 speed
Cluster 11,16,21.
Loose gears
2nd = 42 teeth - 89.10mm dia
3rd = 37 teeth - 79.20mm dia
Primary Ratio 45/14
Stroke = 48mm
ConRod length =
Bore = 57mm
Cento
Cluster 10,15,21
Loose gears
1st = 48
2nd = 43
3rd = 39
Primary Ratio 45/14
Stroke = 48mm
ConRod length =
Bore = 51.0 mm
Lui\J50 Deluxe
Cluster 9,15,20
Loose gears
1st = 58
2nd = 53
3rd = 46
Primary Ratio
Stroke = 34mm
ConRod length =
Bore = 38mm
Early J50
Cluster 10,16,22
1st = 67
2nd = 64
3rd = 56
Primary Ratio 45/14
Late J50
Cluster 9,14,19
1st = 58
2nd = 54
3rd = 47
Primary Ratio 46/13
GP Kevo
I can't choose tires from the drop down menu or alter the tire circumference. It wants a password to unlock the page.
Avantone
GP Kevo wrote:I can't choose tires from the drop down menu or alter the tire circumference. It wants a password to unlock the page.
PM sent......
Tony
    Users browsing this forum: Amazon [Bot], Baidu [Spider] and 10 guests
