Decent reliable Imola carb rubber.
10 inch Terror
Xbox live gamer tag: No.
Hi all, as the title suggests can anyone recommend one? Its for the standard metal inlet which is 35mm in diameter and i'm using a 28mm Mikuni which has a 32mm outlet. I'm currently using a scootrs one but i'm not that confident with it. Any suggestions would be most welcome. Thanks Pete
Monty
I'm using the LTH manifold that has the bolt on rubber so one less pipe clip to worry about. Not much help sorry
Maz
I have recently swapped to a Charlie Edmunds inlet.
Train Driver
Maz wrote:I have recently swapped to a Charlie Edmunds inlet.
pictures, performance update are you saying your scooter is now quicker than mr edmunds ;) ;)
    Users browsing this forum: Amazon [Bot], Google [Bot] and 7 guests
