Mag flange question
Supereibar
Well.. in all honesty I dont follow anyone, but it is in all the manuals that I read, that in order to make a racey engine, you need to make the compression higher. But then again what do I know?
J.
wack 63
Main scooter: '71 GP TS1
I think you will find certain racers already run this set up with an extra seal where the cup spacer sits but don't say I told you ;) Plus high primary compression is so yesterday ,let the exhaust do the work :geek:
wack 63 wrote:I think you will find certain racers already run this set up with an extra seal where the cup spacer sits but don't say I told you ;) Plus high primary compression is so yesterday ,let the exhaust do the work :geek:
Hmm...this is sounding interesting 8-)
rakki
Main scooter: sx|px|rally×2
Muppet wrote:Is that how a vespa bearing is lubed; petrol oil mix,
On Vespas the carb sits above the crankshaft and that helps to lubricate the flywheel side bearing (crank side bearing is lubricated with gearbox oil).
The mag flange I have has a channel running down from the transfer directly into the bearing.
coaster wrote:The mag flange I have has a channel running down from the transfer directly into the bearing.
like this :
Yes Jarv, exactly like that.
cheers
colin
