SIL Crank with Japanese big end bearing
About the same power as a standard Indie crank, but should last much longer,
Keep on keepin on
- corrado
- Dealer
- Main scooter: Lambretta GP
It'd be interesting to know exactly what bearing is used in these. I've had some Yam rods and bearings fitted to SIL cranks and the bearing fitted to the 115 rod was far cheaper than the RG500 bearing fitted to the 110 rod.
