Can you put 100 x 90 x 10 on normal std rim
boxofbits
Can you put 100 x 90 x 10 on normal std rim its on a wide one at the moment but rubbing against casing
Yes, it will give better clearance over wider rims such as ScootRS tubeless too.
Craig H
I have Swalbe Raceman 100x90 on rear no problems so far ;)
you can also get a spacer from Mb to eradicate this problem and keep it on the wide rim.
