imola cylinder heads
sjc
anyone had issues with imola cylinder heads to high compression,,anyone had them reprofiled? cheers steve..
rocho68
sjc wrote:anyone had issues with imola cylinder heads to high compression,,anyone had them reprofiled? cheers steve..
Yes i have , had mine checked and was way out ,had it done and massive improvement
Peter 357 holed a couple of pistons due to head being too high compression.
Beware if it has 'Reaper' engraved on it, bound to have too high a ratio by all accounts.
sjc
just holed my second piston,,motor started pinking over the iow weekend,,talked to a few people and most point out imola run to much compression,,
Skar
What version Imola we talking about? The new one?
sjc
havent got a clue wot version it is,,but its the one with the 4 dowls for the cylinder head,,,
Skar
The mark 3 version has seven stud fixing so I guess you have a mark 1 or 2... I never had any problems with mine and it ran for 7 years before dropping a circlip and knackering the barrel, in that time it only had the rings replaced once. Currently in the process of fitting a new mark 3 kit and just hoping it lasts as long!
