TS1 BAD STARTING
roadrunnerian
HI MY TS1 IS A BAD STARTER FROM COLD WHEN STARTED ITS FINE ANY IDEAS PLEASE THANKS.
need a bit more info tbh..carb set up and so on..
start with a simple one, check your choke is working correctly ie fully opening then check plug is in good condition and is gapped correctly ie.
Its probably a faulty cylinder........sell it to me..... :twisted: :twisted: :twisted:
:lol:
roadrunnerian
HI
I HAVE A TMX 35 CARB JL3 EXHAUST AUGUSTO 7000 AND AN AF LIGHTENED FLYWHEEL.
the-brickie
Xbox live gamer tag: cap willard
At a guess I'd say its the af flywheel.
What stator?
could do with choke jet size so other tmx users can compare with what there using, first port of call for me would be to make sure the choke fully opens..
roadrunnerian
sorted checked the choke found it needed adjusting started 2nd kick thanks for the help
roadrunnerian wrote:sorted checked the choke found it needed adjusting started 2nd kick thanks for the help
Great news..always start with the simple things first.. ;)
No, its definitely a dodgy cylinder.....just post it out to me and i'll look after it for you.
    Users browsing this forum: Google [Bot] and 12 guests
