px125 internals in p2 case?
Suede Ed
Main scooter: SIL GP200
Hello. Got an early P200E engine casing, bare. And an early p125x (points) engine complete, question is are any of the internal engine parts compatable? obviously i,ll need barrel etc, was thinking of gearbox, hub, clutch etc? (done a few lammys but my vep experience as regards engine rebuilds is ltd,at the moment) Thanks
timexit17
pretty sure everything gearbox and clutch wise is a standard fit: top end is different (barrel etc) due to the cylinder studs being space differently.
Svint1
And remember that the gearing-ratio for the 125 is alot lower than for the 200 engine, so might consider geting a spare 200-gearbox.
If not, the engine will rev to high...
Suede Ed wrote:Hello. Got an early P200E engine casing, bare. And an early p125x (points) engine complete, question is are any of the internal engine parts compatable? obviously i,ll need barrel etc, was thinking of gearbox, hub, clutch etc? (done a few lammys but my vep experience as regards engine rebuilds is ltd,at the moment) Thanks
President of Roughnecks Scooterclub
http://www.Roughnecks.no
1965 Vespa SS180 (218)
1971 Vespa 90 Racer
1986 Vespa PX250 (250 Rotax on CNC casings)
1987 Vespa PX210 with Cozy Sidecar
Suede Ed
Crank?
timexit17
think the crank webs are the same size but the conrod is beefier on the P2?
look on sip scootershop and see if you can see a difference between the 2
goldeneye
cant use the 125 crank in a 200 (narrower webs, and a 15mm small end , 200 has a 16mm small end) if you want to swap a mk1 P200 gearbox for your 125 gearbox , PM me. i need a 125 box, and have a 200 here.
