Speedo cable too long ?H
flipster
Alright all,
I ve just fitted a new speedo cable to my special,trouble is I cant get it to work properly.When I turn the inner by hand the needle "flicks" so I presume its ok at the top end. But when its all connected and taken for a spin,nothing. I ve tried shortening the outer by 5 mm as per Stickys book but no joy. Is it a case of another 5 mm off and trial and error? Any tips much appreciated as its doing my head in and I dont want to end up with a too short cable ! :? Cheers.
P.N.D.S.C.
i ended up taking about 10 to 15mm off mine till the inner housed correctly
flipster
So its a case of take a bit more off and try again then. Cheers mate.
P.N.D.S.C.
