SUPER UNLEADED
idc1967iow
I am running a muggy 186 ,is it worth running on super unleaded ?.
Ian :fb:
bristolmod
Hi Ian
I've got a V1 Muggy 186 and always run it on ordinary supermarket 95 RON unleaded and a quality Semi Synth oil . 5 years on and no problems whatsoever.(and I rag it!!)
There is a consensus that the additives in Superunleaded are causing problems (petrol/oil breakdown?)
Hope all is well with you
Shan't be over next week
Scootering since 1968.
Chutney Brownlove
idc1967iow wrote:I am running a muggy 186 ,is it worth running on super unleaded ?.
Ian :fb:
No, but avoid Morrison's cheap fuel, their fuel has a high ethanol content according to reliable sources on here. Not good for our motors.
My tuned motors are set up on Asda fuel, which seems good. I have had more than one strange incident with BP high octane.
If it's an early Muggy I would get the head checked for comp ratio. Some were supplied with far too high compression. Depending on dealer.
sideout
Ian :fb:
That's interesting, our Shell garage has recently been taken over by BP. I've used Shell V-Power for years with no problems. Since using basic BP unleaded I've been plagued on all 3 of my Lambrettas (3 different makes of carb!) with the chug-chug-chugging syndrome when starting hot. Something has changed and I'm jumping to a bit of a conclusion here but it could be the petrol. :?
    Users browsing this forum: Google [Bot], Google Adsense [Bot] and 2 guests
