Spark Plug Cap (TS1)
Boo
Question for all TS1 owners whats the best Spark Plug Cap to use?
ive been using NGK the type where you take the tip off the plug and the cap fits on the thread, everythings fine for a while then the cap comes off due to the vibration i suppose, no fun when ya doin 70 in the fast lane on the M1 :oops:
Lambrettas are for life!
I prefer the rubber type that retains the cap on the plug. that bit of wire on the type you are using does eventually wear after constantly being removed & refitted on that thread.
eibargum
The soft rubber NGK ones that you retain the bit on top of the plug are the best ive used.
mawso
Do the rubber racing caps interfere with TV signals or are they suppressed like the plastic ones? I don't suppose it'll be a problem if they do when we all go digi anyway.
paulmgreen
Definitely use the NGK rubber ones mate...... they are the best
www.JPPLambretta.co.uk
Boo
Cheers lads will give them a go :)
